As part of the residential renovation, we are adding a second level to a single-story house. The house is timber framed with timber subfloor framing on pile timber piles and perimeter ring foundation. The contractor has requested the new level be support by steel beams and posts, like a mezzanine construction. The timber joist and roof framing are support by the steel beams. This works well for hiding the steel posts in the existing walls and then supported on new concrete pad footings. The additional bracing capacity, we were looking at re-lining a number of the existing walls.
Perpendicular to the L2 story joist, the L1 bracing walls are down the hallway, which is at about mid-span of L2 floor joist. We want to get the shear in the walls but do not want to take the gravity load of the floor joist, as the subfloor framing does not have the capacity for the additional gravity load of half the joist.
Simpson has the truss to non-bearing wall connectors - can these be used in floor to wall connections. How do you recommend doing this?
