ivorm
- May 20, 2008
- 11
I'm wondering if anyone could provide some help on a question I have regarding floor vibration and Design Guide 11. I have a steel framed floor, all beams and girders, the beams are all 33 feet long but I have different length girders depending on where I am in the building. Some girders are 33 feet long, while others are 16.5 feet long. When I design the floor using the long span girder to target V1/3 of say 2000mips I get a beam size of W24x68 and a heavy girder at W33x201. If I then try to use that same beam (W24x68) on the bay with the shorter girder (say a W24x55 girder for geometry reasons), I end up with a a higher vibration because of the effective panel weight of the girder is lower and leads to a lower combined effective panel weight. There is a little bit of info about unequal beams and joists at the top of page 26 but I think that's aimed more at girders within the same bay where the joists they support have different spans.
I don't see a way around this problem other than upsizing the beams in the short girder bay to increase the fundamental frequency of the beams and lower the vibration or increasing the short girder size significantly. These solutions will obviously look pretty strange on the plans since the beams are all the same span and have the same tributary width, someone is also going to question a short heavy girder.
Am I missing something here regarding this calculation?
The other confusing thing is the note on page 26 regarding "floor width and floor length". It says "Floor width is the distance perpendicular to the span of the joists over which the structural framing (beam or joist and girder size, spacing, length, etc.) is identical or nearly identical within adjacent bays". How are we supposed to deal with situation like this one where we have very different girder spans?
