Flow splitter modeling
PaEngr
I have an incoming flow from my pond into an outflow control box (1) that has a weir wall (A) within, with a top set to 2-yr ws.
In Box (1), downstream of weir (A) is a 2nd weir wall (B), that has top set to 50-yr elev, and has an orifice opening on its lower elevation.
The 2-yr inflow chamber water is piped-flowed out of box (1) and thru a separate WQ structure, and cleaned water piped back into the upper side of weir (B).
On downstream side of weir wall (B) is an exit pipe.
I can do a simple pond node modeled for Box (1) using its discharge pipe as device 1, and Weir wall (B) and its orifice both discharged into device 1.
But, I would like to add the Weir wall (A) to the node, to document the quantity of water being directed thru the WQ unit. How is this modeled?
You would probably need to model the space upstream of wall (A) as a separate pond. But then you'll have to deal tailwater issues. I would simplify the model rather than trying to include all the details of the WQ unit. Unless it provides a large storage (detention) volume, the WQ unit isn't going to alter the overall hydrograph going through the system. I would ignore the WQ unit and just use weir (B) and it's orifice.
