Flow through multiple orifices
hazzac
Coastal
Feb 27, 2020
3
The water draining from a lake exits freely through a submerged orifice on a vertical wall at the bottom of the lake where discharge is
Q = Area of orifice * Discharge coefficient * (2*g*hydraulic head)^1/2
I need to add two more orifices at the same depth with the same area as the first. How would I find the discharge through the orifices?
Would I just use the combined area of all three orifices in the discharge equation?
Surely each would be the same, therefore 3 x the flow - unless I'm missing something in your posting.
three times the flow as long as they are properly separated. You need to consult the standards in your area and be prepared to run CFD calculations.
A drawing would help.
Do you mean more side by side with no linkage between the orifices or in line?
Does adding more orifices change the downstream pressure?
