When sizing a turbine flowmeter for an application, what will be the accuracy of a flowmeter when say for example the vendor gives the following info:
Repeatability: ± 0.02% typical
Turndown Ratio:
(Models max. rated flow ÷ min. flow rate)
Up to 1,000:1, reduced accuracy
Up to 700:1, single fluid, constant temp.
Up to 300:1, single fluid, variable temp. and visc.
Calibrated Accuracy: ± 0.1% of rate
Linearity: ±0.15 to 0.20% of rate or better
Do we sum all the above or use any one?
Turndown Ratio:
