harlequinir
Chemical
I circulate a hot plating solution using a small, in-tank pump. I want to monitor the flow around 8 LPM using a simple flow or pressure meter. Does anyone make a heat-resistant, non-metal device?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
