Flue parts
xtract
22
GB
Hi, I need to produce a flue design and wonder if there are any part around for 500mm O/D flue parts or if anyone has a tip on how to achieve the effect of the the angular corners seen on insulated flues.
What version of SWx are you using?
Do you simply need a single-part visual model to place in your assembly - or do you need a sheet metal gores that will unfold?
is it a square profile or round? I swept boss feature would work nicely i think.
