Is there a practical limit to a flywheel size in inertia, lb-ft^2 or kg-m^2 on a 500 HP, 480 V, 1800 rpm motor. I would like as big as I can have. For 60 Hz starting, the heat on starting will limit the size and that may be the value listed in Nema MG1. However, if started on a vfd it could be ramped up slowly.
