fo3015 160-iL
drossfree
Materials
Apr 10, 2008
108
i need to know if there is a way to cut without a table inside my machine.
I know I have been able to do it on some machines. It has been a long time though. I'd put both tables out in the shuttle area and then do a tape shot. This is just to see if the beam will come out and or what alarms you get.
Next step is to do a "hole and square" with the trace off and both tables still out. This is just to see what happens.
Point is, try it and see what happens.
Just an update.
ok so if i put both tables outside manually i can run programs with trace off.
thanks
