For flanged Gate valve,150 rating for nitrogen purging , manufacture has done valve test with air as per API598 with 7kg/cm2g w.r.t bid data sheet ,there is no leakages found .However it is noticed,there is leak in valve,with pneumatic test at 13.2 Kg/cm2 (g) at site (pressure as per process line list) as per TPI(Third Party Inspection).I would like to know ,for piping system pneumatic testing to be done including valve or not.Is there any mistake in process line list for medium and test pressure.
Your help would be highly appreciated.
Thanks in advance.
Thanks in advance.
