Force Displacement Tracking - Equation Constraint
MegaStructures
366
Hello:
I'm continuing to try to automate my processes in Abaqus.
As has been the theme in my last couple posts I have a manual task that I need to repeat over and over to complete my research and I'm searching for way to make it more automated.
I am loading the top of an HSS using a single node that happens to be called the "loading node" and then tying the other nodes on the top surface "follower nodes" to it using an equation constraint. I have the need to remesh the parts over and over and every time I remesh the part the node labels inside these node sets change and I have to go in and manually redefine the node sets every time. This is time consuming and rather monotonous. Is there any way I can define these nodes based on the surface and not have to redefine the nodes each time I remesh?
Loading Node:
Follower Nodes
“The most successful people in life are the ones who ask questions. They’re always learning. They’re always growing. They’re always pushing.” Robert Kiyosaki
Scripting should help in this case as well. You can redefine node sets using commands such as findAt(), getClosest() and getByBoundingBox().
