alister1
- Apr 24, 2018
- 2
Hi All,
I am currently looking to specify a hydraulic cylinder and power unit to open and close a horizontal pressure vessel door.
The door weighs 566 kgs and is mounted via a hinge pin that is sat on a thrust bearing (SKF 51202).
The cylinder will be mounted 175mm from the hinge pin at the bottom of the door.
Can anyone suggest the calculations that will be required to solve this? i have attached a basic sketch and the datasheet for the bearing can be found here:
Thank you in advance.
