The site will not let me upload my picture, so hopefully I can explain clearly.
I am going to actuate a pin with a cylinder with a max force of 629N, downward, with a lead angle of 18deg. The pin will then pick up the hole in a cover that weights 14kg, and then pickup an assumed static (it weights 1 ton) hole in a tray, and move the cover into place. The force required to move the cover would be roughly 59N with friction at 0.43, but how do I calculate the force working back up against the pin through the 18deg angle. I did some calculations and came up with a normal force of 167N, but I am second guessing myself. I spoke with a colleague who is good at this stuff and he is also stumped and suggesting using dynamic FEA software to simulate as he cannot come up with an answer either. It is correct to just go back to simple dynamics and use the 18deg, Fn, Fs, Fp based on the cover weight?
Thanks in advance!
Thanks in advance!
