  • Congratulations IFRs on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
format()
bbylls
163
I am looking for information an the format() syntax that can be used in expressions.
I have used ug_setPartAttrValue("DESCRIPTION",format("BAR %3f dia. x ",p0) + format("%.2f",p1))
This gives me a bar diameter of 3 decimal places based on the value of p0 and the length based on the value of p1.
I imagine this can be used in many other ways, maybe as a text substitute, extract, replace, etc?
Did a search in the help file and found nothing.
I am using NX8.
Maybe one of the hidden secrets.
Thank you.
Generally speaking the Expression system honors formatting statements based on standard 'C' string formatting statements, but not necessarily all of them.
The best NX source for help with this is go to the Expression dialog, select the function icon f(x) in the lower left of the dialog, go to the 'String' category and select the 'format' item. Now press the 'Help' icon [highlight #FCE94F][?][/highlight] on the right side of the dialog and you will get a page from the NX Help document showing the supported formatting schemes.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
What version of NX are you running?
But just in case you can't find it, I've attached an MS Word file which shows the content of that help page.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
 http://files.engineering.com/getfile.aspx?folder=fa5898f3-8004-4608-b8a0-b6974a71f671&file=String_Expression_format_statemetns.docx
I'll bet you're running NX 8.0 or NX 8.5, correct?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
