Slaen
Automotive
- Jan 23, 2005
- 128
I’m looking to use trigonometry functions in a formula to get a result dimension. I did a quick example of what I’m referring to as a .pdf which is attached.
I also tried putting a simple trig function in a formula for a dimension to see if it would give me the correct result and it didn’t work so I’m not sure what I’m doing wrong (I put the TAN(45) as the formula for a dimension which should be 1 but it came out to be some long drawn out number not even close to 1.)
Any help on this would be appreciated.
I've attached a .pdf with what I'm looking to do.
