chezzy6
- Nov 29, 2022
- 3
I am trying to replicate an old design from a seasoned engineer, but he is no longer around to ask questions, so I am looking for some opinions. In his previous design, he utilized a combination of piers/footings and slabs for the foundation design; where, in my opinion, they would not be sufficient individually. In reality, I know there is strength between the interaction, but my questions below are about how to quantify the combination on paper.
Typically, in an industrial setting, I will design the piers and footings for the pre-engineered building columns to be independent of the rest of the structure because throughout the life of the structure, it changes so much that it is not always wise to rely on other parts of the foundation to resist forces such as uplift from wind etc.
However, I feel there are situations that this is a little too conservative. For instance, in a large storage building, the use likely won't ever change, so I have the opportunity to tie the piers/footings into the building slab to help resist forces. Slabs vary from 6,8,12" with single or double layers of #5 rebar.
My question is this: if you pour the footing then pour the pier, building perimeter, and slab monolithically, how do you accurately account for the combined strength of the pier/footing and slab?
For uplift, in my mind, you would take the difference between you uplift forces and your foundation weight and the remaining forces would need to be resisted by the slab. Therefore, would you just consider the slab a "beam" on a per foot basis, multiply it by the circumference of the footing and that is your shear and moment capacity of the slab to contribute toward resistance?
For bearing, can you realistically assume the interaction between the two can combine for a larger bearing area? In theory, it would be nice to reduce the size of the footing if your slab can assist in creating a larger bearing area to assist in low allowable bearing pressure situations. However, I am skeptical of this because of the difference in bearing elevation between the bottom of slab and bottom of footing; especially when you factor in the ability to properly compact both areas identically.
As for lateral loading, I don't see many issues as the buildings are typically very large, so the weight of all the concrete is more than enough to resist the lateral kickouts of the [rigid frame] buildings.
Assume load combinations, rebar development length, all the other factors are taken into account.
