Hello -
I am designing a garage with an ADU above. The soils are a moderately expansive clay requiring a 2 - 3 overex. Groundwater has been encountered at approximately 3-4 feet below grade. Due to this I am designing the foundation as a mono pour slab with a turndown. The turndown will extend 24 inches below grade. The grade around the 1/4 acre property does not have enough fall to facilitate surface water away from the foundation using a standard drain pipe and gravel perimeter drain.
Is a perimeter foundation drain warranted? I can't figure how it would be beneficial in this particular situation.
Thanks in advance.
Thanks in advance.
