paulyg
- Oct 23, 2003
- 8
My company has a long history of designing all in fractional or architectural dimensions, except the rare case where you need a tolerance to the thousandth. We deal with mostly castings (sand castings) and fabricated (welded) items. Being a younger engineer I was only exposed to working in decimal until I started here. My personal rule of thumb up to this point has been to design anything machined all in decimal and anything fabricated, especially big stuff (some of the fabrication you could fit inside) in feet & inches (architectural). I am dealing with more and more castings now and am note sure if I should continue to use fractional measurements or decimal. Because of the loose nature of sand casting only two place decimal is really needed. The head of our department doesn't care which method I use. I am curious what the collective experience here has to say about this choice. What is your personal or your company's position? Pros & cons of either choice?
