DoubleStud
- Jul 6, 2022
- 499
So when I have a free standing pavilion/shelter with gable roof but without walls, what are the things I need to check if it is framed with wood? There is no wall. So that means the lateral wind load has to be resisted by the columns and diagonal braces. Shall I just go ahead and specify something to add some kind of moment resistance at the bottom of the post (simpson embedded post base)? Do I just run analysis and make sure the lateral deflection is below certain number? Do I just model it with the braces and assume the base is pinned? How accurate is the deflection if I model it wood? I am afraid the thru bolts give too much play and not modeled correctly on Risa.
