Freelancing
structlady
3
Hi:
I am a structural engineer and wanting to do some freelancing in designing residential homes. I am not sure where to start. I am located in NJ and the houses do not need a PE stamp for construction as in some other states.
Check local laws that apply to engineers practicing architecture. If the houses don't need a stamp, what are you really doing? All houses don't need a stamp or houses under a certain square footage?
Is the question related to how to obtain freelance work? I would recommend looking into the list of local architects and find out which firms specialize in residential construction. Asking contractors/developers in the area is also helpful.
If you are currently employed, find out about company policy related to moonlighting before pursuing.
Good luck.
structlady,
You will still be practicing engineering without a license. The NJ PE Board will jump all over you WHEN they find you.
I do have ny NJ and NY PE licensce. What I meant was to build a residential home you don't have to have sealed dwgs.
I do have my NJ and NY PE licensce. What I meant was to build a residential home you don't have to have sealed dwgs.
I suggest that you review the New Jersey engineering regulations.
New Jersey Administrative Code Title 13, Chapter 40, Sealing documents, 13:40-1.1 (b)
1. The following documents shall be signed and sealed:
i. Maps, plats, reports, descriptions, plans, design specifications, certifications or similar documents; and
ii. Shop drawings for the construction of buildings, structures and related equipment, or for other purposes, the preparation of which requires engineering calculations and/or engineering input. Catalog information and standard product information shall be exempt from the requirements of this section.
13:40-1.2 Title block on drawings; forms; removal
(a) Every licensee shall provide a title block on all drawings (except renderings), and similar information on the title page of all specifications which are prepared and sealed.
(b) The title block shall be in such form as the Board may adopt or approve.
13:40-1.3
(a) The title block shall contain:
1. The name and location of the project;
2. The name of the engineering or land surveying individual firm, partnership, corporation, professional association or professional service corporation;
3. The full name and certificate number of the person(s) in responsible charge;
4. The title "professional engineer" and/or "land surveyor" spelled out;
5. The handwritten signature of the person(s) in responsible charge and the date when signed.
45:4B-7, Building Design Categories, states that residential buildings (BOCA Use Group Classification) may be designed by architects AND that engineers may not design them except for an incidental use.
