In our many american codes and specifications (ASTM or otherwise) where can I find how often a steel shall be tensile tested by the steel producer/manufacturer to ASTM A370? I.e. Once per heat number? Per thickness? Per day? Or at the steel producer's choice?
When I check (for instance) the A36 code and A370 code it does not give this information and I do not know where to look next.
I notice on the mill test certificates for the steels I am looking at there are test results for elongation and yield. So there is indeed frequent tensile testing to some extent.
The problem is that I am purchasing non-ASTM steel for my application which is allowed in the USA and Canada as long as the tensile testing being done conforms to ASTM A370. Furthemore I may have to perform tensile testing at my own expense and I want to know how often based on what code/specification.
Many thanks.
Many thanks.
