I would like some help regarding calculating losses in a split piping system.
The pump has a duty of 200 L/s, from the discharge it splits into two pipes, they re-join 120m down the pipeline.
When calculating the friction losses, do i split the flow and calculate the losses based on 100L/s per pipe then combine those losses for the total losses in the pipework?
Many thanks in advance
