YungPlantEng
Chemical
We have a FRP tank in atmospheric service for an acid. Surface cracks were recognized at a nozzle mated to a stainless flange a couple days upon a prior torque-in-service due to a leaking gasket. Based upon the lack of an expansion joint and appropriate pipe supports (as well as previous visual inspections indicating small cracks) it is believed that excess compression from the torque activity on the upper section of the nozzle increased crack diameter and depth.
From approximately a week of marking we haven't noticed any indication of crack propagation. I was wondering what literature is out there for crack propagation on fiber-glass reinforced systems (non-carbon fiber). My admittedly primitive understanding of FRP as a material and how crack propagation occurs in stainless vessels leads me to believe the crack is inactive until further stress placed upon it via expansion/compression loading from temperature fluctuations.
We're currently coordinating a complete nozzle replacement but I wanted to do a little more research to see if delaying the repair to a later date would be viable with remediation of the pipe support / expansion joint install.
Thank you!
Thank you!
