FT&A
RandomDesigner
Aerospace
Is it possible to get constructed geometry ( passing planes in this case) to show when I display a capture? I have used capture management, shown it while active in the capture, tried the constructed geometry management, etc. I can associate tolerances and dimensions to them, but when I display a capture they would be more helpful visualized.
Have I not been clear in what I am asking, or is it just a stupid question?
Negative, if you hide or show it, it just stays that way, no matter what capture you display. I only want to show these items in select captures, not all the time. A co-worker found that utilizing the attribute tab under the properties contextual menu of the specific capture (RMB), there is a box to check for management of part bodies and geometrical sets within the capture. This box also appears under tools/options/functional tolerancing and annotations. Thanks though.
