EngGab
- Aug 6, 2018
- 5
Hello Friends.
I have doubts about the manufacture of this type of valves with these characteristics, I will greatly appreciate the support they can give me.
It is required to install a branch of 3/4 "Ø for an instrument, this on a line in service (42" Ø), this will be done through a hot-tapping, therefore a ball valve is required, full port, 3/4 "Ø, SW x NPT end connections and at the customer's request, this valve must be 1 piece.
However until now I have not found a model that meets these characteristics 100%. My doubt of particular way for this type of valves in this diameter, if they are manufactured in full port of 1 piece. Since until now the models that I have found for full complete are of 2 or 3 pieces and for 1 piece only with reduced port, This basically for the maintenance of the internal ones.
Are full port valves manufactured in 1 piece?
In case of knowing about a manufacturer of this type of valve, I would appreciate your sharing the information.
If this topic is already published in another thread, I will appreciate the link. Thank´s.
