WSTOK
- May 9, 2021
- 1
I have a 3306NA CAT engine running off EICS system paired with a Centurion system. Unit dies randomly from 45mins to 30 hours. It shuts down on EICS Shutdown, when checking codes in EICS (on M-View touchscreen-7) it shows ESD Shutdown.. No other code or issues. Unit does not act different or anything when shut down either. It's as if you just hit the stop switch. Emergency switch is not activated, switch works good. All wiring has good connections, grounds are good.
Thank you for any help!
