chemeng12345
Chemical
- Aug 28, 2007
- 6
- 0
- 0
When designing a gas distribution header system, does the order at which users are put in the line affect the system? This may be a stupid question... I'm not sure.
I am thinking that because the pressure in the header is controlled upstream of the users, it doesn't matter what flow rate each individual user takes, all users should see the full controlled pressure at their end of the pipe.
Is this correct?
Is this correct?
