nesamani1983
Hi all, I am working in Gas pipeline transportation, has cross country pipelines and terminals.
I have below doubts
1) Is there any way to find the terminal pipe grade? any survey . Because in old terminals, pipe/bend materials used are of different thickness than the A333 or A106 Gr B. Also the documents are not available.
2) Kindly send me the sample calculation for Minimum required thickness as per ASME B 31.3
3) If the terminal piping, "measured thickness" is less than the "Minimum required thickness as per ASME B 31.3", what action to be done?
If the terminal is operating less than the Design pressure, can we do any Engg assessment and accept the metal loss?
I have below doubts
