It really depends on your tubular size. 4-1/2 tubing in 5-1/2 casing would not flow much up the annulus. 1-1/2 tubing in 12-inch casing would flow a lot more up the backside than up the tubing.
Typically, the annulur area is significantly larger than the flow area of the tubing so you would expect to see more flow (for the same bottom-hole pressure and choke size) up the backside than up the tubing due to lower friction drop in the larger area up the backside.
The unloading issues with velocity strings are much more a long-term issue than a well-test issue. Again, this is a really complex ananlysis that is not done by "rule of thumb" you have to know your reservoir and your design goals for a specific well.
David
