Ehiman1
- Oct 17, 2014
- 59
Hello guys,
I have to calculate a bolted joint with two welding neck flanges against high pressure with a particular gasket that I never used.
This gasket has trapezoidal shape and I would like to know if it exists a calculation for this type of gasket.
Code is EN13445 and pressure is 280 barg with Carbon Steel material (heat exchanger)
