Jun 1, 2003 #1 yvonne Industrial Sep 14, 2002 22 0 0 GB Hi I need a cad drawing of a 6" gate valve 2d or 3d thanks
Jun 1, 2003 1 #2 mqas Materials May 17, 2003 55 0 0 IN Yvonne, Parallel Slide, Wedge Gate or Thru Conduit? Pressure Class? Flange type - RF, RTJ, BW etc Manual, Gear or Actuated? Cad format ? dwg or dxf format can be supplied without any problems. Lastly, what do you intend to do with this drawing Regards Upvote 0 Downvote
Jun 2, 2003 Thread starter #3 yvonne Industrial Sep 14, 2002 22 0 0 GB Hi The gate valve I had in mind is a parallel slide manual format DWG My use for the drawing is a project I am doing at college as part of my research into cad Thanks Upvote 0 Downvote
Jun 3, 2003 #4 mqas Materials May 17, 2003 55 0 0 IN You can post your address on this site or e-mail me direct and I will forward you the drawing you require. vduffy@weirvalve.com Regards Upvote 0 Downvote
