I am designing and building a gazebo to cover a ground level deck patio and wondered if I could get some input on the design. Pictures are attached (with some dimensions). Roof pitch is 3/12. Roof sheathing will likely be 1/2" OSB (unless something else is suggested) and roof covering will be architectural shingles. Posts, beams, and braces are 6X6 Treated Pine. Gazebo will be free standing (not attached to the house in any way). The posts will be anchored to concrete pillars. I live outside of Huntsville, AL so snow isn't really a concern (4 inches is basically a blizzard), but we do get strong winds occasionally. I currently have the rafters modeled as 4X6s which is my primary question.
1. Are 4X6s or 2X6s sufficient for the rafters? Would 2X8s be better? I would like to avoid adding additional posts if possible. If the span is too large, can I add another beam to each side and add a brace in the middle for additional support?
2. Any other design thoughts/suggestions?
