I am looking to simplify drawing for a sheet metal component. It's a custom handle used on a standard ball valve so the tolerances can be pretty loose. The complex shape makes it difficult to clearly and completely dimension. I know that the vendor is going to use the model to laser cut the flat shape. Our quality team is going check the important dimensions and for the rest, they will hold it up to a clear overlay. Considering all this, I am looking to call out the important dimensions and then create a global tolerance that ensures that the general shape matches the model. I was thinking of placing a global profile tolerance in the notes that cover all undimensioned surfaces. Can I do this? If there a better way? Drawing is attached.
