Smwdrum
#1) if the parts are case harden you must calculated the circular tooth thickness, from span width & or Measurement over wires. use standard practice for the amount of stock removal vs the type case hardening required. add stock to the gears for final processing. you have to make sure that during case hardening cycle the case depth is pinched to the high limit to allow stock removal with out deviating the hardness and case depth.
#2) if it is through harden the amount of stock is irrelevant except for efficiency.
only add enough stock as needed to do the job with the most efficient manner.
what the pre grind data has to have is # teeth, DP or MOD, Pressure angle.
calculated Measurement over wires or span which is based on the pre-grind CTT.
attributes like the the pre grind lead, run out, minor diameter can ether have a protuberance or the minor diameter has to adjusted for grinding. in other-words add stock for final finishing.
fillet radii at the minor diameter.
these are just some of the millions of scenarios that can be.
every job has it special circumstance.
Does the operator have the right tools to manufacture. does he have the correct whole depth, can a hob be used or does it have a shoulder next the the gear or spline. so then a shaper cutter must be used.
Does the operator have all the machine data that is required for his or her machine. like change gears, right dressing tools, correct holding tools.
whats settings for that particular machine does the operator need. check the manuals or and ask the operators. they will thank you for it.
the pre-grind data will be very close to what the finish data has but will be more liberal on tolerance because it is roughing.
Mfgenggear
