General Effects of Lateral Load on Steel Member
IlliniPE
This is a very general, possibly hypothetical, question, but I was wondering if anyone has come across any literature that gives a rough estimate for the increase in steel size for lateral loading vs only vertical loading. I ask because I have a client that wants to know a rough comparison of steel needed for two separate vertical loading conditions. For these preliminary discussions, would it be fair to say lateral loading will result in an XX% increase in steel size? That is, the columns need to be W12x30 considering vertical only, but an increase of 30% in strength would be in the ballpark for lateral loading, too. I know there are many factors that determine those lateral loads, but I was wondering if an upper limit, conservative number had ever been determined. Would it even be possible to do so for quick, schematic purposes?
I'm going to assume that you mean to compare two cases:
1) Columns and beams for gravity loading only.
2) Columns and beam used for gravity loading and for lateral loading (wind/earthquake), in the form of moment frames.
If that's accurate, I doubt that you'll find a meaningful rule of thumb. That, because most buildings nowadays concentrate building lateral resistance locally. So a given frame might take only 1/20th of the gravity load applied to the building but wind up taking 1/2 of the lateral load applied to the same building.
Your odds might be better if you were looking at a building where all of the gravity columns were also moment frame columns, as has been done in some retail buildings historically.
Yes, for moment frame applications. Forgive me, it has been quite the Monday. This is for a nonbuilding structure that will consist entirely of moment frames. I realize now just how vague and general my question was. But yes, just searching for any sort of rule of thumb, mostly just for conversation sake.
I'll be interested to see what others come up with but, even with that simplification, I'm at a loss. Consider:
1) Heavier buildings will suffer from P-Delta effects more greatly.
2) A rule of thumb for weight, if it exists, will likely be eclipsed by the need to consider the cost of the different manner of beam/column connections between moment frames and gravity frames. Most of the cost may wind up in the connections. This might actually be a viable path forward if you consult with a fabricator on the relative cost difference between moment frame connections and gravity frame connections.
Your initial instinct might be right: it needs to be a literature thing. Maybe some one has done a parameter study or something in the past.
The only relevant experience I have is in looking at those retail buildings that I mentioned earlier. One story malls where every column is part of a moment frame. In those situations, I feel as though maybe a 50% increase in weight would be in the ballpark.
How many stories is your structure and what is its function?
Way too many variables IMO. I agree with KootK that the connection costs with MF's can easily dwarf just upsizing the steel sizes. I think asking a fabricator who does a lot of steel building type structures would be your best bet.
