General Service Pumps 1
spartan117
18
What is considered a "general service" pump in downstream refining? I would have thought any utilities, water services, etc. are considered general service, but the terminology is also mentioned in API 610 when referring to inspection levels.
Thanks.
A general service pump is a pump designed to cover a wide duty and application base using the minimum of pump models by maximizing interchangeability of components.
Hello bimr,
Would that mean the definition is independent of process conditions?
