Geometric imperfections, Buckling analysis SAP2000
rleclercq
CA
I am currently studying a simple model V&V with SAP2000. I managed to compute buckling analysis, but I want to compute buckling analysis with geometrical imperfection (L/1000) to compare the value with the code equation Cr=AFy/((1+lambda^2n)^(1/n)). To include the imperfections, I tried to applied a lateral load corresponding to the shape of the mode 1. Is it the best way to include imperfections ?
Thanks for your answer,
Raphaël
If you're doing an Elastic Buckling analysis then you should directly model the imperfections? You want them included in the initial stiffness matrix.
Do you mean model imperfections manually ? I tried with curved frame but results are not as expected. And it's seems really long because I want to do a sensitivity study about the initial imperfections effects.
Yes, I mean manually adding in the imperfections. I'm not sure how SAP models curved members. So, I was really talking about breaking the member into at least two pieces so that you can offset the joints to the initial imperfection you were looking for.
If you want to capture the imperfections in the buckling analysis you will need to model the deflected geometry, not the ideal geometry, as Josh says.
Imperfection can be imposed by many ways such as:
[ul]
[li]modeling of the deformed geometry[/li]
[li]apply horizontal loading[/li]
[li]do nothing as imperfection will be introduces because of the small arithmetic errors within the computer calculations, such as 1e-10[/li]
[/ul]
Jason McKee
proud R&D Manager of
Cross Section Analysis & Design
Software for the structural design of cross sections
Moment Curvature Analysis
Interaction Diagrams
Reinforcement Design etc.
