I have a question regarding the geotechnical torsional resistance of a drilled shaft.
After calculating the skin friction (force), do we need to subtract any axial loads (shaft self-weight and any applied loading on top) to get a net resistance force, and then use this force time shaft radius r to get the torsion resistance. Or, directly use skin friction times r?
Thank you!!
Thank you!!
