Get the required proprties from the property window from the bundle segment in catia v5 using vba
Sidtha
Aerospace
Nov 25, 2012
36
Hello All,
I have written below code to select the BNS from the catia tree and i am getting all parent node and other details.
But unable to get the properties like show in below picture. Could some one please help me to get the result.
Result should be:
Type: Bundle Segment
Reference designator: BNS0001
Diameter: 6.2mm
Bend Radius: 37.2mm
Length: 238.199mm
Flexibility: 3
Sub test_BNS()
Application.ScreenUpdating = False
Application.DisplayAlerts = False
Dim wb As Workbook
Dim ws As Worksheet
Dim MyProduct
Dim ShtNumber As Worksheet
Dim ShtRef As Worksheet
Set wb = ThisWorkbook
Set ws = wb.Worksheets("FIN_Data")
ws.Range("A2:I100000").ClearContents
lr = ws.Range("A" & ws.Rows.Count).End(xlUp).Row
j = 2
Dim CATIA As Object
On Error Resume Next
Set CATIA = GetObject(, "CATIA.Application")
If Err.Number <> 0 Then
Set CATIA = CreateObject("CATIA.Application")
CATIA.Visible = True
End If
On Error GoTo 0
'--------------------Define CATIA------------------------------------------
Set CATIA = GetObject("", "CATIA.Application")
Set MyDocument = CATIA.ActiveDocument
Set MyProduct = MyDocument.Product
MyRootPN = MyProduct.PartNumber
MyRootInstanceName = MyProduct.Name
MyDSType = Left(MyRootPN, 4)
'--------------------ApplyDESIGN_MODE------------------------------------------
MyProduct.ApplyWorkMode DESIGN_MODE
CATIA.StartCommand ("Fit All In")
'--------------------Select BNS------------------------------------------
Dim objSel As Selection, oSel As Selection
Set objSel = CATIA.ActiveDocument.Selection
objSel.Search ("Name=BNS*,all")
j = 2
For i = 1 To objSel.Count
Set prod1 = objSel.Item(i).LeafProduct
Set myParameters = prod1.Parameters
Dim element As Object
Set element = objSel.Item(i).Value
partParent = objSel.Item2(i).LeafProduct.PartNumber
PartZone = objSel.Item2(i).LeafProduct.Parent.Parent.PartNumber
ws.Cells(j, 1).Value = MyRootPN
ws.Cells(j, 2).Value = PartZone
ws.Cells(j, 3).Value = partParent
j = j + 1
Next i
End Sub
wrong forum for your question - please re-post correctly and delete this one
Could you please let me know where i can post this.
Thank you
I could help if I understood what you're talking about . . . but I don't, plus I am not doing your work for you.
I suggest you peruse the list of forums and find the one which best covers your topic of interest.
