Glyphs 1
looslib
Does anyone know where I can get a FULL listing of the glyphs used in the assembly and model tree. A partial listing is in the Fundamentals Help topic book, but many assembly ones are missing.
This simple thing is what hurts PTC. How can someone learn the system if the icons/glyphs are not explained. I don't want something this simple to be ONLY in some training manual, it should be in the Help section. People tend to forget what one means after a few years.
Ben Loosli
Pro/E is pretty slow on the icon generation front.
Many menu items have no icons at all.
Their UI customization Tools > Customize differs only slightly from release 2001.
You can create your own icons in Pro/E but they are 20 x 20 pixels in size.
There is no icon for Blend but you can copy the icon from the display in the Model Tree and then open in an image editor and select all copy and paste the icon onto a Mapkey.
What is the point of icons if you have to use object action Pick /Select to see the icon become available to click.
Maybe your question should be
"How can someone learn the system if the icons/glyphs don't exist."
One Thing I'd suggest is to add additional columns in your model tree for assembly type icons. I use Feature Type and Subtype to easily see whether a feature is a solid or surface because For many Wildfirized Tools that allow Surface or Solid to be chosen unlike SolidWorks which has two icons for each command Extrude, Revolve, Sweep, Loft etc.
Michael
[jester]
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
Follow me on ?w¡???
- @trajpar - @Shweep -
- ProE - SolidWorks -
I am looking for the model tree glyph definitions like unconstrained component, flexible component, bulk item, etc.
Ben Loosli
I've uploaded a file with a list from 2008, I don't know that it was complete then & certainly not now but it's the best I have. I agree, PTC should make this info easily available, what's the point of having symbols in the model tree that just make you go Huh?
 http://files.engineering.com/getfile.aspx?folder=4d468392-367b-4868-a239-6e0cefb393f3&file=ProE_WildFire_Model_Tree_Icons.doc
I was able to go to PTC's website and under support go to help centers and from there pick the release you have and do a search within the online help for model tree icons. Seemed pretty complete for me.
-J-
