GOST
qqquaker
Computer
Nov 27, 2001
5
Can anyone tell me where can I find more detail,info about Russian Standard (GOST) equivalent to AISI, and ingredient combination as well. Is Metalinfo good resource ?
The Russian GOST mark is pretty messed up. Right now rule of thumb is " if you can apply a CE Mark to your product using EU standards then you can submit your product for GOST approval. The trick is knowing someone with the right connections. I've received approvals before but it means doing a CB report. If your interested in the information e-mail me or call with your product information. Christopher Caserta
Sr. Regulatory Engineer
ccaserta@enorthhampton.com
Ph:904-225-0360
Fax:904-225-0340
