.gp4 file? 1
DanDel
940
Is anyone familiar with a .gp4 drawing file? Apparently, it is a 'GTX Group IV' or an 'Image Systems Group IV' format. I have a drawing in this format and I can't open it.
I believe this is a CALS1 format that you will have to insert has an image into a blank dwg.
The only way I know of editting such a format is through CadOverlay.
Hope this helps!
Thanks, CADQUEEN, but can this be done with AutoCAD 2000i LT? The 'Insert' pull-down does not have 'Image' as an option. I don't need to edit it, just open it and print it.
No, you are out of luck with LT, it doesn't support images.
If you like you can e-mail me the file and I would be more than happy to make it a tiff or JEPG for you.
Then you can just open and print it through Microsoft Paint.
let me know it will only take me about 3 minutes to do.
cathrine.strollo@fpa
I think this might work for you, I find so many helpful sharewares on Cadalog.com!
Do a search for GUTHCAD CAD Viewer 3.2.
Description:View and Print AutoCAD drawings up to version 2002. Designed to be especially easy to use for the non-CAD user, but even CAD professionals will appreciate features such as Back and Forward browsing, and multiple file selection and batch printing.
Other features include:
Simple User Interface.
Read BMP, JPEG, TIFF (including LZW), GP4, CAL, GIF raster formats.
Read HPGL, HP-GL/2 (.PLT) plotter formats.
Browser style Forward/Back buttons allow multiple (up to 120) drawings to be loaded simultaneously.
True Type Fonts.
3D pre-defined and user defined Views.
Can be called by other applications as a window for Viewing and/or Printing.
Enquire on Attributes attached to entities, Xdata supported.
Layers control.
3D Shade / Render.
Inquire on individual entities.
Thicken printed line widths.
High quality print output.
Print to Exact Scale.
Save to raster.
Batch print multiple drawings.
Text Search.
Text Touchup.
Handles Xrefs, Paper Space/Model Space, Layouts.
Direct read of CAD files inside ZIP files.
let me know if it works for you!
Good luck,
Cassy
