rendevouspoo
I'm an EIT and so far the most confusing part of the job is the site grading. When I see my boss do the grading, it appears to be the easiest thing in the world but when I'm looking at it, I just can't see it.
Are there any quick references I use for Max/Min slops, preferred, ect when it comes to grading?
Also, once you set your building, do you usually leave a fairly flat area outside of it for a certain distance? If so, how much? I'm new to this forum and will contribute when I can. Thanks for the help!
