gravity
jisb007
Bioengineer
May 14, 2005
33
I'm using standard to simulate how a bowl of gel deforms under its own weight. I defined the contact between these two as frictional BC. I don't understand why I get some very strange result -- the deformed gel has part "outside" the bowl container, something not physically possible. Does anyone have any idea what might be wrong? Thanks!
Before we can suggest a possible remedy or potential problem, you'll need to describe exactly how you're modelling this.
See faq569-1083 for details on how to make best use of Eng-Tips.com
Initially you may have had one surface outside the other and without using *adjust this will remain so. Otherwise it could be that some nodes have passed through the slave surface (or is it master?).
corus
