NickParker
- Sep 1, 2017
- 397
When we run parallel runs of cables for star-delta starters, (3 phase, 6 wire cables); Say, If I run 2 sets of 3 core cables, is it necessary to run 2 runs of separate ground cables too.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Not under Canadian codes.However, it is permissible to run two separate conduits, one with an adequately sized earthing conductor and the other conduit [without] an earthing conductor.
Not where I live. This practice is absolutely prohibited by the Canadian code. There is a reason.b) It is also permissible to run a single-core or multiple singe-core insulated or non insulated earthing wire in another separate conduit [without] any power cable;
This is permissible under the Canadian code if the current is below 200 Amps. This applies to ferrous conduits.Attention: It is [not] permissible to run [only one single-core [[power wire]] ] in a metallic conduit.
