CuriousElectron
- Jun 24, 2017
- 191
Greetings,
I have a question regarding sole plate and foundation bolts. In a scenario where a metal sole plate is anchored to concrete with anchor bolts, and over time, if a ground movement occurs, would the torque value on the anchor bolt change relative to the original torque value? The anchor bolt is installed vertically.
Would this horizonal ground shift, even if it is less than a millimeter, would if cause the loosening of the bolt?
EE
EE
