surineman
- Jan 5, 2005
- 33
I have a grounging study for a new water treatment plant.
We have to design the grounding system for this plant.
The plant is located on a granite rock outcorp and soil resistance clearly is high.
Depend on spacing of probes the resistance changes from 330 to 102.5 ohms.
we want to run a 4 odd cable along the storm sewer pipe (which is PVC) for nearly 200 ft and connect it to a ground rod buried 20 ft and backfill the hole with ground enhancemet material and have an extension pigtail for a grid connection just in case we have not got the appropriate resistance.
also we considered some ground rods around around the building and 24.9/600 v transformer connected to the 200 ft cable.
since I have never done a grounding design before, I gathered information here and there and I am not sure what I am doing.
Any references, materials, thoughts, helps would be highly appreciated
