YMA18
- Dec 16, 2021
- 3
I need to patch a void in a grout pad. The void area is 7" wide x 3-1/2" deep x 3/4" high. The grout used in the pad is Dayton 1107 Advantage Grout. I am thinking of using the same grout type to patch this void. The Dayton 1107 Advantage Grout has an expansion ratio 0.11% which seems sufficient to seal the seam between the new grout and old grout.
I am also thinking of placing a steel form on the void with two ports. One port is the grout input and the other port is for the grout output. After grout comes out from the output port, it means the void is full. Prior to grouting, I will roughen the surface area in the existing grout where the new grout will be applied to to have a good bond between the new and existing grout.
Does anyone have any thoughts or concerns regarding this patching procedure? Anything missed?
