Nythius
- Sep 22, 2024
- 3
This feels like a stupid question, but after extensive googling and searching these forums I still don't have an answer...
New nonloadbearing CMU wall going to underside of existing slab (or any structure for that matter). Slight gap for deflection of course. Partially grouted with bond beams and verts. My question is what is the best detail at the top... how do you get grout into the top course?
Below is what I've come up with:
-bond beam at second course from top
-verts stop at top of second course (so you can "drop the blocks over rebar")
-grout fill with top course not in place
-wet-set little 16" dowels so you have at least something extending to top course
-then install top course (need to cut slots in face to slide it in with rebar already there...)
-drypack the cells with verts in the top course
-install "retainer angles" for out-of-plane restraint
see attached screenshot.
Alright...fire away...prove I'm an idiot.
Thanks in advance,
Thanks in advance,
