I can make a wild guess what voltages are represented by H1, H2, H3, but I'd rather not.
What you call space heaters are most likely anti-condensation heaters.
Normal practice and recommended practice is to run anti-condensation heaters at half rated voltage.
Most common is 240 Volt rated heaters supplied with 120 Volts. It doesn't take much heat and the heaters lasr forever.
